Overclock Settings for a2000 Mining Warthog
Hi there,
I was hoping that someone could help me out with some overclock settings for mining Warthog using a2000’s or if they could point me in the right direction. I’m having a difficult time getting them stable.
Thanks in advance for any and all help!
Adam
same as the other core only algo coins like kaspa/alph/pyrin etc.
memory locked to 810mhz and as much core as you want to run, you can also add as much as is stable core offset after.
Okay! I will go ahead and give that a try and play around with it to see what works best. I got the 4070 supers working well but I haven’t gotten the a2000s dialed in yet.
Thanks, again, for your response! I really appreciate it!
