OpenVPN Connection Problem
Hello guys. I’m trying to connect my rig to my personal VPN. I created a .ovpn file which looks like the one below. However, it sets openvpn configuration just fine but I cannot ping anywhere, thus the miner fails to connect to mining pool. The very same openvpn connection works with my own PC. What am I missing here?
client
nobind
dev tun
remote-cert-tls server
remote xxx.xxx.xxx.xx xxxx udp
<key>
-----BEGIN PRIVATE KEY-----
SOME IMPOSSIBLE TO CRACK PRIVATE KEY
-----END PRIVATE KEY-----
</key>
<cert>
-----BEGIN CERTIFICATE-----
   SOME CRAZY LONG CERTIFICATE
-----END CERTIFICATE-----
</cert>
<ca>
</ca>
key-direction 1
<tls-auth>
# 2048 bit OpenVPN static key
-----BEGIN OpenVPN Static key V1-----
SOME INDESTRUCTABLE STATIC KEY
-----END OpenVPN Static key V1-----
</tls-auth>
redirect-gateway def1
