Hi everyone,
Been having trouble with my rig. I just added a 1080 to my 2 1070 rig with more varying cards on the way.
Overclocking hasn’t been an issue until I’ve tried running the ethpill for the 1080. Enabling the pill under just that card enables it under all cards in the oc settings for some reason.
Ok…so I check to see how to set the params in the eth pill, because for some reason if you turn it on for one card it turns on for all. Literally just put 0 in for device 0 (the 1080) and the rig ran for about 8 hours before crashing. I hadn’t even bothered to limit it’s power yet, as I wanted to minimize what could be causing issues.
It works fine with the two 1070s. It works fine with the 1080 alone. It works fine w/o the ethpill (1080 + 2x1070). With it, and the 0 param to make sure only it gets the pill it works for about 8 hours before crashing.
Thoughts anyone? Any and all help is appreciated.
