Hi guys, I recently turned my 6x rx580 RVN rig to ERGO and have some statistical differency when I checked out my stats. Can anyone give some advice about my OC settings? Dropping my OC settings here.
The goal is to find the lowest core clock that gives you full hashrate, the highest memory clock that gives you max hashrate and that’s stable, and lowest voltages that the core and memory will run at.
         Thanks man. I will try to use for it. İf cards give me problems about it, then I will look for RVN or ETC.
