Greetings,
I got an ASUS B250 Mining Expert motherboard with 13 GXT 1080s running. Currently, I am using the following OC settings to mine ZEC using dstm:
CORE 60
MEM 650
FAN 80
PL 165
with the following dstm extra config:
temp-target=0:64,1:64,2:64,3:64,4:64,5:64,6:64,7:64,8:64,9:64,10:64,11:64,12:64
If I run 12 cards I get around 565 sol/s per card on average and everything is stable. If I add the 13th card to the mix, however, I am getting errors after a few minutes of mining - either one or more cards stop mining at this stage but the rest are working OK.
My question is: Is anyone using a similar setup and found success - if so may I kindly ask you to provide any feedback around the OC settings mentioned above - am I completely off? I will try running the cards with stock settings in the meantime and gradually increase the OC to see at what stage I start hitting issues.
Thanks in advance,
M
