I have 1 PowerColor SK Hynix H5GQ8H24MJR · 113-C9403100_101
And when I change bios with Polaris, whatever settings I use, the invalid shares start and in the pool the GPU reported as 0 mhs.
The temp looks good.
What can be the issue?
Hi, does anyone knows how can I improve the hashrate of the 580 GPUs? The last one is an MSI Armor OC Edition. Thanks.
Hi, those percentages are Fan settings on your GPUs… 100% - red, 60% - blue…
After flashing the vbios, I found this OC stable with teamredminer. Anyone please let me know if you have a better OC with similar power usage. I have started getting invalid shares when I had made change to this OC.
Hi, I just did the same OC and got the 32.x mhs, using teamreadminer. I will test it, to see if it will be stable. Thank you
Hello i need bios mod for this RX580 ASUS DUAL EPLIDA please anyone can send me bios modded for this thanks …
Actual hash is 25 normal i need 30 32 thanks…
I have 2 RX 580 on my rig:
- MSI RX 580 ARMOR OC 8G
- ASUS STRIX RX 580 O8G
I could get about 33.5 mh on first one but couldn’t get more than 30.05 for the ASUS Card (SK HYNIX).
these are my tunings,
anyone can suggest me to have better efficiency for ASUS card?
even for MSI?
Best Regards
Can you send me this bios, maybe I can leave high hash and legal consumption, with some changes.
Can send anyone to me bios oc for rx580 gigabyte hynix memory please?
Great job… Please advise us for OC setting …
Please post on WhatsApp
+989356059423
Thanks Buddy but I couldn’t get more that 28.2 MH on this Config.
What is the Last part of chip about?
(115-D000PIL-100)- what is this?
You’re 101 but I’m 100!!
I don’t know what the last part means. It should give a little more than 28.2MH, try with the memory 2120 and going up by ten o twenty and see if you can reach 30 or 31MH at least.
alguma sugestão para minha rx 580 ou ate mesmo a 1660s:
não consigo aumentar os mh sem aumentar a potencia, energia onde moro é caro então queria reduzir no maximo, será que é necessário biosmod? quero buscar algo em torno de 30 mh ja tentei usar outras config aqui do forum mas sem sucesso.
Can you pass me this bios please
up plis
