no i didn’t insert memory controller voltage 800
yes the aggressive undervolting is ON
I have never brought the core voltage below 850 In the pictures, I saw that with the same numbers, the voltage is close to 80, but for me it is 95
put 800 and to memory controller voltage and see what happens .
my card with 1168 core, 865 core voltage , 800 memory controller and 2100 is 100 watts so yours are a bit better.
I heard that the memory voltage should not be manipulated because it is very sensitive
I reduced the core voltage to 825, but the Rig error reduced hshryt and did not bring some graphics, but from 96 watts to 91 watts.
I went back to 850
If you reduce something reduce it by 5. And dont worry about the memory. Mine is 800 volts the memory controller voltage
Thankful
So I change the memory voltage
Memory controller voltage not the memory voltage itself.
Now memory controller voltage is 800 and reduce 3 watt of any graphics
Another friend told me to use the team red miner software, but I do not know how
i am mining with phoenix miner currently it gives me better results.
in the flight sheet you can change the miner used. you can select team red miner of phoenix miner and see how it goes.
OK
I have not used any software before and I am in the viabtc pool
I will test And I would like to join flexpool
phoenix is drawing higher hashrate than it is in real. TRM is more fair miner in this term, and power managment is better.
Thankful
Now I extract with trm
With hshryt 31.15 and 83 w
Lower your core and VDD… (core 1200 - vdd900) and lower your mem…2050-2100
Could you please share the OC setting and bios mod for this card ( Radeon RX 580 8192 MB · PowerColor Samsung K4G80325FC 113-C9403100_101 ).
Thanks so much.
can you send me that custom bios
hola saludos desde colombia
Disculpe la molestia ,donde puedo conseguir la bios de la rx 580 8 gb gigabyte?
Hi
Send pm to Watsapp messenger
+989356059423
