Hi guys, I can’t solve the OC problem, the OS doesnt wan’t to work properly, I tried to downgrate Nvidia driver for the 455.45.01, I tried with re installing Hiveos on a another SSD drive, and it’s still not working. I read that sometimes unistalling the AMD driver should work, but I don’t know how, I use " amdgpu-uninstall " but it doesnt know the command apparently… It worked at the begining 2/3 times in a row the same day, then nothing yet.
Can someone help me ?
Thank you guys !
NVS query error:
=== GPU 0, 01:00.0 GeForce GTX 1070 8117 MB, PL: 92.5 W, 185 W, 208 W === 07:49:28 SET CLOCKS: 0 MHz SET POWER LIMIT: 185.0 W Max Perf mode: 3 (exitcode=1)
=== GPU 1, 06:00.0 GeForce GTX 1070 8119 MB, PL: 100 W, 200 W, 250 W === 07:49:38 SET CLOCKS: 0 MHz SET POWER LIMIT: 200.0 W Max Perf mode: 3 (exitcode=1)
=== GPU 2, 07:00.0 GeForce GTX 1070 8119 MB, PL: 75 W, 166.1 W, 200 W === 07:49:48 SET CLOCKS: 0 MHz SET POWER LIMIT: 166.1 W Max Perf mode: 3 (exitcode=1)
=== GPU 3, 08:00.0 GeForce GTX 1070 8119 MB, PL: 76 W, 151 W, 170 W === 07:49:58 SET CLOCKS: 0 MHz SET POWER LIMIT: 151.0 W Max Perf mode: 3 (exitcode=1)
