Nvidia-info temperature
Currently, nvidia-info does not show the GPU temperature. You are already grabbing the temperature from the card in the nvidia-info script ( $temp ), but you do not display it. The following change to line 42 in nvidia-smi will display the temperature:
            echo -e "${PURPLE}Current PSTATE  $pstate , PWR $pwr, FAN $fan, TEMP ${temp}C${NOCOLOR}"
Can you make this change in the official HiveOS release?
Thanks!
Thank you for proposal. After next update maybe …
Thanks!
Did you see my other post a while back about modifications to /hive/bin/wd and /hive/sbin/autofan regarding sreboot?
please give links to these posts most likely I missed them
Thanks! Here is the thread - Feature request for autofan and watchdog
Ok will look on it too
Thank you again!
