I’m having problem with the installing new driver,
i start with nvidia-driver-update it starts to unpack driver and then stock with [ OK ] Started Hive. and completely freez.
Any ideas how to deal with this?
Interesting thing that the same thing happened with older version of drivers 460.39.
Also when i stop cuda sudo init 3 I get the same screen
Resolved it by installation of beta HIVEOS.
Are you using the 3060 on hiveos to ether mine ?Are you using the 3060 on hiveos to mine ether? If so, are you having low performance due to the blocking of nvidia?
Im minning conflux on nicehash. You cannot mining ether on Hive os without restrictions with 3060.
