I want to share the wireless Internet connection from my 1 rig to my second rig via an ethernet port. will this work:
On the gateway
- Enable ip traffic forwarding:
- Open
/etc/sysctl.conf - Uncomment the line
- Open
COPY
net.ipv4.ip_forward=1
- Reload using
sudo sysctl -p /etc/sysctl.conf - Reconfigure ip_tables to allow NAT:
- Download the attached file
- Replace
online_devicewith the name of the network device that provides the internet connection - Replace
lan_devicewith the name of the network device that connects to the LAN - Run the script with
sudo
On the client PC
Add the gateway PC as the default gateway using
COPY
sudo ip route del default
sudo ip route add default via <ip of gateway pc>
Add another DNS server to /etc/resolv.conf , for example
COPY
nameserver 8.8.8.8
thanks for any advice.
