No wlan0 interface found
I need your help. I try to connect my RIG with wifi but I have the message " No wlan0 interface found".
I try some tips from :
ttps://hiveon.com/forum/t/wifi-setup/3335/13
https://www.reddit.com/r/gpumining/comments/r95gw8/wifi_command_on_hiveos_not_showing_networks/
But nothing works.
I have a BTC 37 motherboard, a TP Link N150 wifi dongle.
I already put wifi settings (SSID and password) in files of HiveOs.
Can someone has an idea to help me ?
Thanks a lot
If the wlan interface/nic is not showing up as available via USB, its driver is not likely in the current kernel package.
You would need to install a compatible driver.
Thanks but how can I do it ?
did you try running wifi
Yes, I have this :
And then when I try lsusb :
I don’t know what to do now.
As grea said, try installing a driver. Maybe the hive install doesn’t have drivers for all wifi cards. Also there are a few posts here about usb wifi adaptors
So I am having the same issue, but past hiveOS OS’s have worked just fine, why the heck is it now not working?!?!
Wifi not working on the now hive os only the order version any solution
Im using these on latest stable and beta and they work as expected https://a.co/d/6wm2hpE
You can look for Ubuntu 20.04/22.04 (depending on which image youre using) drivers/install guide for your wifi adapter also
I have 6 rigs same problem with different USB WiFi Adapter all not working on the now hive
