hello,
i was trying to mine with my 6800xta but when I start HiveOS only my other cards works. It just shows the card but no temps or something else.
If I try to run my GPU on Windows (same riser) it works just fine.
What could be the Problem?. (5700 works just fine)
What hiveos kernel version are you running?
Maybe update the os.
Comand:
hive-replace -y -stable
Can you post a screenshot of your worker overview screen?
