I’m starting with Hive OS but apparently it is necessary for Hive OS bootup to connect your monitor via the GPU op the X16 PCI-lane? Currently, when starting up, I’m getting ’ OK Started Hive’ and nothing happens. Apparently, the reason is that I have my monitor connected to onboard VGA?
Problem is, I have three rigs: one has trouble sending a monitor signal via GPU, thus I have the monitor on VGA output. The other two consist of mining cards only, which have no output.
Is there a way to solve this?
