No connection on reboot (wifi)
Hi, I have the following problem:
When my rig reboots (say, after a gpu clock error) hiveOS doesn’t recognize the wifi adapter. If I unplug it and plug it again it does, and in a normal start up it does too. This is annoying because I can’t use features like hashrate watchdog, or test new OC settings if i’m not next to the rig in case it crashes and reboots without connection.
Has anyone encountered a problem like this? Is there a good solution, or at least a provisional workaround?
Cheers!
Having same issues with two rigs, can’t find an answer yet
