NEX Chain (NEXC) Ethash flight sheet settings for AethelBlock
I operate AethelBlock. Here are manual Hive OS flight sheet settings for mining NEX Chain (NEXC, chain ID 6396).
  1. Add a wallet with your public NEXC address.
  2. In the flight sheet choose Configure in miner, then select Ethash.
  3. Set the server to nexc-pool.aethelblock.com:3082 for PPLNS or nexc-solo.aethelblock.com:3083 for SOLO. Use your public address as your username and x as the password.
  4. For lolMiner use --ethstratum ETHPROXY. For GMiner use --proto proxy if that mode is not already selected. Check the miner log for an accepted share, then verify the worker on the pool dashboard.
Both modes have a 1% pool fee and a 1 NEXC minimum payout. Dashboard and setup guide.
Rigel alternative for NVIDIA rigs: set the algorithm to ethash. If you are entering the arguments manually, use one of these commands and replace YOUR_NEXC_WALLET with your NEX Chain receiving address.
# PPLNS
rigel -a ethash -o ethproxy+tcp://nexc-pool.aethelblock.com:3082 -u YOUR_NEXC_WALLET -p x
# SOLO
rigel -a ethash -o ethproxy+tcp://nexc-solo.aethelblock.com:3083 -u YOUR_NEXC_WALLET -p x
On Hive OS, if the flight sheet already supplies the algorithm, pool URL and wallet, use those fields and avoid duplicating them in Extra Config Arguments. After switching modes, check for accepted shares and look up your worker in that same mode on the pool dashboard.
