New to Mining and stuck with ok hash rate and very few shares
I just setup HiveOS and have 1 3060 LHR, while mining ETH I’m getting 30+ hashrate (with no overclocks). But the number of Shares is really low, only 2 share in 13 mins. Can anyone please make a suggestion ?
poolside hashrate is all that matters. and set ocs, no ocs is worse on the card.
Thanks, I’ll do that and try to let it play out a few days.
The reason why you are getting a few shares in 13 minutes is because the difficulty of the pool. If you look at your screen, it says diff: 8.73G. If you connect to a pool that has a lower difficulty, you will submit more share. That could be a good idea for you since you only have a single 3060. This is how I run my single 3060 V1. Because I have a V1 card, I keep it separate from the rest of AMD and Nvidia cards I have.
Good luck
