One might be running into issue with “nvtool” error with the latest release HiveOS version:
[email protected]
the problem being that the nvidia driver included version being 470.86.
To fix this problem, install this version instead:
[email protected]
This release contains the nvidia driver version 470.82, which works fine with the newest Hive OS version (at the time of writing, being: 0.6-214@220331) and has no issue with the nvtool, and also works with the new VRAM temperature display which is being supported by many miners nowadays.
Also, a minor issue, under the individual worker page, the motherboard info is currently not being displayed properly:
which shows “Default string Default string (5.19 12/09/2021)”
Hope this helps!
