Network is offline check your internet connection (FIX SOLUTION)
Well i have fixed the problem of that …
i just change the archive rig.config from the USB
i have to add that is normally a fix for alot of problem in sistem just change that archive and the problem must gone
excuse me~
could u tell me to slove the problem?
in the morning , suddenly miner can’t work, and i try to restart the miner
Ok. But change what exactly?
I have same problem.
how to fix it?
