Negotiation of Eth-Proxy compatible failed. Change you connection Parameters [HELP]
I was running fine then our of nowhere this happened and I dont know how to fix it… anyone have any clue?
Cleared everything in the net-test except the 114.114.114.114 Ping - which says check my internet connection.
I have this same issue. Have you figured it out??
