Need help with OC and settings
Hello, Just started working with 1 card and here are my stats and OC settings? Do you think everything looks OK? Any tips or comments?
Thanks!
Looks decent. The goal is to find the lowest core clock and lowest voltages that maintain max hashrate and stability. Also the highest memory clock that gives you the highest hashrate as well, some cards if you go too high they actually perform worse so it’s a trial and error type deal to find the most optimal settings.
Thanks!
