I bought vega 56 and never worked with amd before
i have 8 vega 56 on ASRock X370 Pro BTC+ with dual 1300W platinum PSU, i only changed mem to 900mhz avergae 41mhs per card but crashes after couple of hours with teamred miner
, any help would be greatly appreciated <3
Exact same thing happens to me too. I can get 40 m/hs mining ETH with Phoenix, but crashes every couple hours.
try this with teamred miner
@mjavor I have 8 gpu and for some reason, i get less system crash with 7 gpu
I have 2 platinum 1300w
Just a quick update for people having trouble with Vega 56 cards
Its running stable with 8 gpu now on these settings
also added timing from command line โwget https://github.com/mostnonameuser/HiveTweaks/releases/download/1.1/timings.tar.gz && mkdir /home/user/timings && tar -xvzf timings.tar.gz -C /home/user/timings && cd /home/user/timings && ./initโ
HI
I am new on hive os, can you help me to do the same settings as yours as I have the same GPU ?
Where those values like core , vdd/vddci mem should be inputted?
Thank you .
This worked for me! I am getting about 35MH/s from each card but at least they are all hashing away!
Thank you!
Iโm getting 50-53 MH/s with my Vega 56 cards (start mem at 955/965 and decrease by 10 if youโre getting too many invalid shares). Mine are mostly all Powercolor Red Dragon, with a few MSI cards. The attached screenshot has 1x MSI Vega 56, 6x Powercolor Red Dragon Vega 56, and GPU 1 is a Powercolor Red Devil Vega 64 flashed with a Red Devil Vega 56 bios.
Got most of my setup from here: Vega 56 and Vega 64 guide
Iโm using the below strap (paste it into the Advanced Config section of the OC panel for each individual card):
Appreciate the help! Will give this a try after work today
