As the topic states I have a rx550 that I just added to my rig and I can see it on rig start up , but it won’t mine with teamredminer or xmrstak.
Is there a way to fix that ?
Thank you in advance for the help
Is it an old hiveos installation? Probably a driver problem. Easiest way is to simply reinstall a fresh image of Hiveos.
Bad ass man that did it . I though I had the most recent but I guess not on this rig
Thank you !
