Unfortunately yes.
It seems this is a common problem with these cards…
Why not use newer miners?.. NBMiner is really unupdated
Which one do you recommend? I remember I tried a lot of them when I moved to Hive but none of those were as stable as Trex and Nbminer. I used these on Windows as well.
You are having problem with some Memories GPUs you will get with lol which is the GPU problem.
Using nicehash add --enablezilcache in the configuration with lolminer to do faster movements in the Nicehash changes DAGs.
For example that helps me a lot to know which GPU is over Memory:
Also if you check pools resulats at Analysus Hash at the pool you will see the results are good. I also not recommend to split miners, If 6 gpus gets 5 shares, splitting 3+3 gpus don’t get 2.5+2.5 shares, they get 2+2, that is 1 share less.
