Navi 23 Radeon Pro W6600 Hiveos BUG 0.6-211 Overclock does not work
Hello everyone, after readed the latest build changelog
in HiveOS 0.6-211
  • Added OC support for AMD Radeon PRO cards: PRO VII (Vega20), V520 (Navi12), W6600 (Navi23)
    but after mounted a rig with 7 W6600 we can’t reach to powerplay with them
I have tried everything but nothing can change core clock that stuck at 500 Mhz, and memory clock stuck at 1074 Mhz, can someone of Hive team provide support for this problem?
Mon Nov 15 08:41:05 EET 2021
Detected 7 AMD cards
GPU BUS ID : 03 06 09 0c 0f 12 15
CORE_CLOCK : 875 900 1200 900 900 900 900
CORE_VDDC : 700 700 720 700 700 700 700
CORE_STATE :
MEM_CLOCK : 880 875 1100 875 875 875 875
MEM_STATE :
MVDD :
VDDCI :
SOCCLK :
SOCVDDMAX :
REF :
FAN :
PL :
AGGRESSIVE =
=== GPU 0, 03:00.0 Radeon Pro W6600 8176 MB #0 === 08:41:06
Default Power Play settings from VBIOS for Navi20
CORE Clock max: 3050MHz, Voltage: 825-1150mV, SOC Clock: 418-1280MHz, Voltage: 806-1050mV
MEMORY Clock def/max: 875/950 MHz, Voltage: 1250-1350 mV, VDDCI: 675-850mV, TC: 1
POWER PL: 100W OV: -6%/+20%, TDC GFX: 125A, TDC SOC: 18A, TEMP Target: 95C
Warning! No core clock is set - using {cclk}MHz fail safe clock
Applying changes to Power Play table
SOC: 1280MHz@1050mV (TDC Limit 18A) VDDCI: 850mV MVDD: 1350mV
Applying OC via SysFS API
Setting CORE: 1350MHz@700mV MEM: 880MHz
Setting Fan speed set to Auto (HW)
=== GPU 1, 06:00.0 Radeon Pro W6600 8176 MB #1 === 08:41:07
Setting CORE: 900MHz@700mV MEM: 875MHz
=== GPU 2, 09:00.0 Radeon Pro W6600 8176 MB #2 === 08:41:07
Warning! No memory clock is set or out of range - using 875MHz as fail safe clock
Setting CORE: 1200MHz@720mV MEM: 875MHz
=== GPU 3, 0c:00.0 Radeon Pro W6600 8176 MB #3 === 08:41:09
=== GPU 4, 0f:00.0 Radeon Pro W6600 8176 MB #4 === 08:41:09
=== GPU 5, 12:00.0 Radeon Pro W6600 8176 MB #5 === 08:41:10
=== GPU 6, 15:00.0 Radeon Pro W6600 8176 MB #6 === 08:41:10
REPORT of TeamRedMiner:
[2021-11-15 08:43:32] Mining ethash with 7 GPU workers
[2021-11-15 08:43:32] GPU PCIe CUs CoreMHz SocMHz MemMHz TEdge TJct TMem FanPct FanRpm VDDC Power ETH Cfg
[2021-11-15 08:43:32] 0 03:00.0 28 500 1200 1074 54C 57C 64C 23.92% 1368 693 mV 45 W A270
[2021-11-15 08:43:32] 1 06:00.0 28 500 1200 1074 56C 59C 66C 23.92% 1368 818 mV 47 W A336
[2021-11-15 08:43:32] 2 09:00.0 28 500 1200 1074 55C 58C 64C 23.92% 1368 718 mV 45 W A288
[2021-11-15 08:43:32] 3 0c:00.0 28 500 1200 1074 57C 59C 64C 23.92% 1368 818 mV 50 W A288
[2021-11-15 08:43:32] 4 0f:00.0 28 500 1200 1074 57C 60C 66C 23.92% 1368 818 mV 49 W A288
[2021-11-15 08:43:32] 5 12:00.0 28 500 1200 1074 59C 63C 64C 23.92% 1368 818 mV 49 W A336
[2021-11-15 08:43:32] 6 15:00.0 28 500 1200 1074 58C 60C 66C 23.92% 1368 818 mV 48 W A304
[2021-11-15 08:43:32] Stats Uptime: 0 days, 00:07:01
[2021-11-15 08:43:32] ----------------------------------------- GPU Status -------------------------------------------
[2021-11-15 08:43:32] GPU 0 [54C, fan 23%] ethash: 20.82Mh/s, avg 18.42Mh/s, pool 2.423Mh/s a:1 r:0 hw:0
[2021-11-15 08:43:32] GPU 1 [56C, fan 23%] ethash: 20.42Mh/s, avg 17.97Mh/s, pool 12.12Mh/s a:4 r:0 hw:0
[2021-11-15 08:43:32] GPU 2 [55C, fan 23%] ethash: 20.58Mh/s, avg 18.10Mh/s, pool 9.703Mh/s a:3 r:0 hw:0
[2021-11-15 08:43:32] GPU 3 [57C, fan 23%] ethash: 20.61Mh/s, avg 18.16Mh/s, pool 33.98Mh/s a:11 r:0 hw:0
[2021-11-15 08:43:32] GPU 4 [57C, fan 23%] ethash: 20.45Mh/s, avg 18.02Mh/s, pool 21.85Mh/s a:8 r:0 hw:0
[2021-11-15 08:43:32] GPU 5 [59C, fan 23%] ethash: 20.54Mh/s, avg 18.14Mh/s, pool 31.58Mh/s a:9 r:0 hw:0
[2021-11-15 08:43:32] GPU 6 [58C, fan 23%] ethash: 20.48Mh/s, avg 18.09Mh/s, pool 29.16Mh/s a:8 r:0 hw:0
[2021-11-15 08:43:32] Total ethash: 143.9Mh/s, avg 126.9Mh/s, pool 140.8Mh/s a:44 r:0 hw:0
[2021-11-15 08:43:32] ----------------------------------------- Pool Status ------------------------------------------
[2021-11-15 08:43:32] daggerhashimoto.eu.nicehash.com ethash: 143.9Mh/s, avg 125.1Mh/s, pool 140.6Mh/s a:44 r:0
[2021-11-15 08:43:32] daggerhashimoto.usa.nicehash.com ethash: 0.000 h/s, avg 0.000 h/s, pool 0.000 h/s a:0 r:0
[2021-11-15 08:43:32] ------------------------------------------------------------------------------------------------
