My Hive OS has been running for more than 30 hours,but I didn’t receive any payment.What’s the problem?
I am a newbie please help me
You’d need to look at the pool youre mining to and see what it says.
Keep in mind nexa has a 5000 block maturation time so basically there is a 7 day delay in payments for nexa unless the pool is fronting the nexa, again you’d need to check with the pool.
Also 21000 in the mem field is out of range and not being applied. For nexa you actually need less than stock, you can change to -2000 and should save you some power
Correct
Thank you
