I guess you are right.
Short update,
After many trials i got the right mh/s for the 3070, i had decided to return the 309 to much grief with the Inn3d fan stating at 99-100% all the time even the temp was down to the point the other 2 fan wouldnt move but 3090 was on 100%
I will shop around for probably an 3080 if i can find if not 2 x 3070 they do run like a charm
they work like a charm.
you still want to increase the mining ? what are you doing when ETH stops mining , switching to others ?
Yes i will increase, i wait on the refund of 3090 and will buy 2 x 3070.
When ETH go’s down will mine RVN, Firo or Ergo, i’m already doing with a pc like 20mh/s RVN just to get a start on it, seems good.
I do not expect/need a quick return so i can play the long game.
What 3070’s you think is best for mining (given the fact that i will find the one recommended.)
check here this dude MSI RTX 3070 Gaming X Trio - Same Model but different hashrate - #20 by AdWiix he has MSI running at 62mh/s.
