My 1660 Ti Settings
Yes, I wish I had bought more of the 1660 TIs instead of the 3060… lovely little devils…
I mine with RaveOS, phoenix miner and have differnet 1660 ti and super GPUs. These are my settings (maybe it can help someone :)):
Bought an ASUS desktop - does anyone have any suggested settings for this card:
GeForce GTX 1660 Ti 5944 MB · ASUS
Micron GDDR6 · 90.16.29.40.52
I believe its a newer version, was only able to get ~28 mh/s with the settings shared in this thread
Testing 1035/3900 currently showing 32 mh/s @ 84 w and 43 degrees
Is there anybody tried to update vbios to 1E or 2B from 90.16.20.40.EC for Asus 1660ti TUF Micron Memory Card ? When i try this on Hiveos it gives me below error:
NVIDIA Firmware Update Utility (Version 5.728.0)
Copyright (C) 1993-2021, NVIDIA Corporation. All rights reserved.
Checking for matches between display adapter(s) and image(s)…
WARNING: Firmware image PCI Subsystem ID (1043.8854)
does not match adapter PCI Subsystem ID (1043.8840).
WARNING: None of the firmware image compatible Board ID’s
match the Board ID of the adapter.
Adapter Board ID: 0121
Firmware image Board ID: 018B
You are intending to override PCI Subsystem ID.
Are you sure you want to continue?
Press ‘y’ to confirm (any other key to abort): y
Overriding the PCI Subsystem ID mismatch.
NOTE: Exception caught.
Nothing changed!
ERROR: Board ID mismatch.
@tax1040, i used your setting of 1035/3900 with 84 PL and got 31.42. Earlier was 28.8 only. There is a small increase. Thank you!
Questo è il mio settaggio per le GXT 1660TI come mi scosto non va piu bene
