Multipe driver versions on same rig
Hey
I have multiple rtx 3060s and unfortunately one of them is one of the new Gigabytes LHR cards.
So I cant even use the lolminer fix like with the other cards. So all of the other cards run on the 460.39 driver which crashes when I try to put the LHR card in.
Is there any way to install another driver just for the LHR card? So that all of the cards run on the 460.39 and the LHR card runs the newest driver?
Thanks in advance
you cant sorry. you have to update it to 465 and work with it.
