This is the first time that I am doing bios modifying. I might not know a lot of things or I maybe did something wrong. Bare with me please.
I just got a second hand MSI RX 570 ARMOR 8G OC card.
Used following software on Windows OS.
- Used PolarisBiosEditor and One Click Timing Patch. Software asked me to apply best settings for Micron memory and I accepted.
- I uploaded modified bios on card using amdvbflash and everything was good.
I did not test its before/after MH rates and directly put bios modified card on my rig.
My current values are way lower than any other RX 570 card I see in the forum. I only get 19.22MH out of it and that is with over clocking.
Details are as following:
NOTE: amdmemtweak --REF 0
This settings are something I picked up from a preset and modified slightly using another RX 570 that I saw in the forum.
Below is my stock bios timings
Below is my modified bios timings
Anything over 1500 and up is same
I wonder if there is anything that I did wrong so that card is not mining around 30MH
Any help is appreciated.
Thanks & Regards,
Ertan
