MSI MECH 6600 (non XT) Micron oc settings help
I own a couple of these 6600 with Micron memory and I’m breaking my head figuring out settings that will work with these cards. Anyone have any recommended settings that work? Any help is much appreciated.
I’m using Teamredminer
typically its best to find your own settings. find the lowest core clock that gets you full hash then find the lowest core voltage that’s stable, continue with memory and memory controller voltages
Thanks for the tips. I will try that out. Thank you!
