MSI 6600 XT problems
Trying to mine Flux. I get Device 0 detected as crashed wth lolminer and GPU driver error, no temps with gminer and lolminer. I don’t have any OC set besides fans at 50 percent because the auto fans will not work. On boot up the fans kick on then stop and won’t work unless I set them manually.
I’ve installed the new HiveOS, switched risers, switched cables, switched PS cables around, switch USB drives. I was mining on a GTX 1080 and a R 280 and R 290 without any problems. This started as I installed the 6600 XT and any info I find says to lower your OC settings, which I don’t even have any set at all.
