MPH help setting up
Need help setting up the wallet i thought i had it and ended up not having it
Please explain what you do not get
Set your worker name on HiveOS to whatever you want it to be on MPH and then you can use my script below.
Try this:
POOL: us-east.ethash-hub.miningpoolhub.com:20535 WALLET: %EWAL%.%WORKER_NAME%, PSW: x, ESM: 2, ALLPOOLS: 1
So I am not sure which of your MPH’s you are trying to set up? the only one that would work right now would be SnowyV.2 as it is setup for every mining type and SnowyV.1 and SnowyV.SnowyV_1 are set up to Equihash
