Motherboard for mining with 6800XT
Hi Everyone! I am making a new rig with 6800xt? could you recommend some motherboard to 5 or 6 gpus? best J!
I use this from some time and it work pretty good: MSI Z390-A PRO.
Hi! Thanks for your advice. A choose ROG STRIX B460-H Gaming, I put 5 Gpus ( one using nvme port). I dont know if I have a Bios configuration missing, but one of my 6800xt doesnt go up of 58MH. The others one are at 62.5 MH. Are you using the AMD driver to do the overclock ? I am using clocktune for minerstat. Thinking to go with HiveOs, but need more time to take this step.
Hi, when i try my 6800xt on my pc, i mine using amd catalyst for overclocking but after i use it on my rig which run on hiveos and is working fine, around 62 mh. You should check how you power your gpus.
