Since it seems with proof of work Ethereum mining has failed, I am trying to set up to mine Monero, using MyMonero wallet. (The wallet itself might be an issue! Please confirm if it isn’t accepted by HiveOS and what wallet should I use in this case)
So I created a new wallet new flight sheet, attached it to the miner, using nanopool and hoped it will just going to start mining to the new wallet (old one was for ETH chain only)
When I login to the miner and check the agent screen, xmr-stak shows Hashrate xmr-stak 1.2707 kH/s (after some zero kH/s)
But I don’t see anything on HiveOS (note - I turned off watchdog cause thought the error minimal hashrate not set might have caused some issues)
My question can be summarized as please help. What am I missing? What else should I be checking? Thank you
