Mining rig wont start, got this problem
What do I have to do? Is it just one gpu or all?
Hi man!, y will try to help you!
Sets the voltage supply on the memory chips (MVDD). Currently applicable only for Navi family cards. The default value is 1350 mV. The permissible range is 1250-1350 mV. Use this parameter only if you understand what you are doing otherwise you can get a very unstable system.
Get on oc settings and read the ! helps!
