My rig does something strange on hiveos.
gpu 3 isn’t working on hiveos but when I get him out in other rig the GPU is working fine (with same clocks or without any clocks) and then another GPU of this rig wouldn’t able to use? also tried to swap some gpus in the same rig but that doesn’t work either. not a specify riser or gpu powerline is the problem.
So there is always one card that doesn’t work… (only when I have 3 gpus in it then it works fine)
before runned this rig with 6 gpus without any issues…
does anyone knows this issue and how to fix this?
its a 1200W power supply (yes a bit overkill for the RX 6600 XT ^,^
