Mining flux with nvidia card not does nor work
Hello, I can’t mine the flux
with my Nividia cards (the ether mining is done without problem)
Despite multiple reboots of the worker or the miner, this does not change anything, do you have a solution?
thank you
Try this:
After done mine eth, delete you hive os, and build new hive os acount, than you can mine anything!
