@846875 I typically see about 1.5% to 3.5% less in the miner than reported in HiveOS over the long run (after at least a few days uptime). In the short term the miner will show all sorts of results but take the long term average if your comparing vs ETH. Right now its considerably more profitable on ERG for Vegas.
@lil ERG has a short period after each block is solved where no mining occurs, and if you watch the miner it stops mining and builds a table each time a block is solved, that is why you see the drop in hashrate approximately every 2 minutes(ERG average block time). Nothing you can do to prevent it, its just how ERG works.
Ill give a try with those straps, i belive i have had them on allready but not with core 1404. From this rig i have that and one and 1 ref 56 that is giving me headache…they both are stable but not optimal “greedy” !
