I want to set the minimum fan speed on the 3060 and 50hx video cards. But my attempts are also unsuccessful.
I tried to set the autofan to the minimum value of 8,12 and below. but the fan speed did not drop below 30%. i suspect this limit is set by the hive os operating system itself, because windows can lower the speed from 1 to 100%. i also set the minimum value from the overclocking section the same minimum values but it did not show below 30%. then i wrote to technical support and they also could not answer this question. is it possible to reduce the fan speed below 30% by any other means?
Translated with DeepL Translate: The world's most accurate translator (free version)
