I had a problem mining in the Binance pool, the MHs of Hiveos and Binance are not the same, so binance has been paying me the equivalent of 305MHs, while in hiveos it says that I am mining 370MHs
Do you have any idea what could be going on?
Is that average? Or real-time?
Also, your 3090 clocks could use work, turn off autofan and reduce the core clock to around 1150mhz, and if you’re still thermal throttling reduce memory clock until you’re not.
