Hi all, Ive just converted from Windows10 (way to many crashes etc
I’ve got a few 1080ti’s but can’t get and memory tweak commands to work , I’m using NBminer at the moment using “memory-tweak”:“6” in the user config box.
It’s just not noticed when the miner is started.
Cheers
make sure you’re matching the syntax examples in the info bubble in miner config exactly. for a single value it looks like you’re missing a space and have extra quotes.
Ok I have managed to find what @keaton_hiveon mentioned! (ThankYA)
I am using the NBMiner instead of Gmine and configuation section I added “memory-tweak”:“4,5” under extra arguments. Which effects only GPU 4 & 5 (please correct me if I am wrong!). I restared my miner and the magic happened
Now my 1080s are not as slow as before.
