Memory load not showing on dashboard
I have just started mining on HiveOS and HiveOn, but I get no memory load indication on the dashboard.
Is there a way to show it correctly?
You typically will not get an answer here - I suggest you try their chat option - they do sometimes answer
And as an aside that is not memory load - it is in fact actual fan rotation speed as a percentage of what you set it to
