Thanks. I gave 2miners another try and things are looking better. They have an average hr close to the card’s speed.
The number of shares between the two pools doesn’t compare, as you pointed out because of vardiff. However, it is now only half instead of a sixth of the shares. Guess there was a problem and must have been fixed by now.
Though I should be rather low on the difficulty range because of my hashrate (44 on 2miners). Have more cards running on flexpool than on 2miners, so that should had made the vardiff on flexpool harder.
Even set up another instance of lolminer to reduce that variability. Could be that there is something wrong with the config for the miner lol
2miners
Statistics (13:55:49); Uptime: 2h 54m 2s
The api is active on port 44445
Algorithm 1: Ethash
Connected to: eth.2miners.com:12020 (86ms latency)
Algorithm 2: SHA256-TON
Connected to: https://next.ton-pool.com:443 (104ms latency)
      Name        Speed   Pool  Shares    Best    Eff.    Speed    Pool   Shares
                   Mh/s   Mh/s  A/S/Hw   Share  Mh/s/W     Mh/s    Mh/s   A/S/Hw
GPU 8 RTX 3060 Ti 43.94  36.77  44/0/0  457.1G   0.342  1022.05  954.25  145/0/0
Total             43.94  36.77  44/0/0  457.1G   0.342  1022.05  954.25  145/0/0
         Best    Eff.  Power  CCLK  MCLK  Core  Junc  Fan   LHR
        Share  Mh/s/W      W   MHz   MHz  Temp  Temp  Pct   Pct
GPU 8    3.7T   7.955  128.0  1230  7920    63    75   63  80.9
Total    3.7T   7.955  128.0
Ethash: Average speed (10s): 43.94 Mh/s
SHA256-TON: Average speed (10s): 1022.18 Mh/s
flexpool
Statistics (13:55:52); Uptime: 2h 54m 3s
The api is active on port 44444
Algorithm 1: Ethash
Connected to: eth-us-west.flexpool.io:4444 (36ms latency)
Connected to: https://next.ton-pool.com:443 (93ms latency)
GPU 0 RTX 3060 Ti  40.80   34.86   91/0/0  337.3G   0.328   971.65   927.84  141/0/0
GPU 1 RTX 3060     35.80   33.32   87/0/0  955.0G   0.319   807.18   769.91  117/0/0
GPU 2 RTX 3060     36.19   36.77   96/0/0  632.2G   0.301   780.46   789.65  120/0/0
GPU 3 RX 6700XT    45.94   39.45  103/0/0  334.1G   0.484   551.29   598.82   91/0/0
Total             158.73  144.40  377/0/0  955.0G   0.351  3110.58  3086.22  469/0/0
         Best    Eff.  Power  CCLK  MCLK  Core  Junc   Mem  Fan   LHR
        Share  Mh/s/W      W   MHz   MHz  Temp  Temp  Temp  Pct   Pct
GPU 0    5.9T   7.804  124.0  1110  7920    63    76   N/A   67  83.5
GPU 1   32.5T   7.194  111.7  1350  8400    62    70   N/A   56  79.9
GPU 2    5.1T   6.491  119.7  1380  8400    61    69   N/A   41  79.5
GPU 3    8.9T   5.813   94.3  1210  1069    45    51    66   33   FHR
Total   32.5T   6.885  449.8
Ethash: Average speed (10s): 40.80 Mh/s | 35.80 Mh/s | 36.19 Mh/s | 46.00 Mh/s Total: 158.80 Mh/s
SHA256-TON: Average speed (10s): 971.77 Mh/s | 807.15 Mh/s | 780.49 Mh/s | 552.02 Mh/s Total: 3111.42 Mh/s
