Hi all, im newbie in mining!
This is my spec for my first rig:
Motherboard
PRIME Z590-P ASUSTeK COMPUTER INC. (1017 07/12/2021)
CPU
2 × Intel(R) Celeron(R) G5905 CPU @ 3.50GHz AES
Disk Model
ATA Samsung SSD 860 250GB
1x 3070 asus dual
1x 3070 LHR PNY
1x 3060ti LHR Gygabyte
My ratio is low
How resolve this problem?
i try with some OC preset but this is the result
the Hashrate for the 3060ti and 3070 LHR is very bad right?
for lhr cards youre much better using a miner that offers a partial lhr unlock, currently trex miner is best. also, switch your 3060ti clock to 1500mhz instead 0f -500, and remove power limits from all. should make everything happier and gain you ~22mh
