How can I activate low power mode for Antminer L7 miner? Is there any command to add in Extra config arguments?
What firmware are you running on?
I ´m using last stable version for Asic Hub: 1.10.0.1111197911
Asic miners run their official Antminer firmware ( last available version).
Thanks.
I have added that command to the flight sheet but it doesn´t work. I have tested it in Antminer L7, S19 and D9 but work mode has not been modified by the flight sheet in any of them.
please try replacing the 0 with a 2
I have tested it with the same result, it doesn´t work. Thanks for your support
If you find any other command to try , please tell me.Thanks
Can you send me a link to your farm where the L7 on stock fw is?
just wanted to update with the solution here as well for anyone looking in the future,
- make sure to update to the latest test branch release in asic hub
- then use:
"bitmain-work-mode":"3"in the extra config field
