Hi, I’m using 4xGTX 1050ti. I only get ~1.5 Mh / s from one of my cards. What would be the reason? Thank you!
Capture: https://i.imgur.com/52nNsa1.png
[quote=“bbmi;126”]Hi, I’m using 4xGTX 1050ti. I only get ~1.5 Mh / s from one of my cards. What would be the reason? Thank you!
[/quote]
In most cases first at all check riser card, power connectors etc
If not help check another card in this slot
I changed the OC profile and the problem is fixed. Strange but i don’t care
am also having same issue and new for mining .am using GTX 1060 3GB - 5 cards. One card working very low hashrate pls suggest me the best OC
cardshttps://forum.hiveos.farm/uploads/editor/5y/04qjwy9pe4lo.png
