Hi everybody,
always got this error, anybody knows whats wrong. I was mining for the last 3 Months without any problems and now this pops up every 30 minutes.
Thank you very much for help, i will try to reinstall hive
Hi everybody,
Any OC changes ? i see a dead GPU, also have you made any updates ? Bad internet?
Hi, I have the same problem. My RIGs works fine since 1 year without problems, but it shows the same errors now… I saw that it crash (for example teamredmining) and then shows “start_mining.sh” but its a sh**.
Did you found any solution?
Thx!
i see you have update of the OS maybe you need to update it. and then check if the problem remains.
exactly the same problem .
i m mining fine since 1 year and that happen last sunday.
i have two rigs ( only Radeon VII mining on EZIL ETH+ZIL) and i switch every part of the rigs.
the bug came from the storage … when i switch HDDs problem switch from rig one to rig two.
on miner : start_mining.sh → mining 5 min on Ethermine … i can’t see the wallet adress… but not mine
so now i try to make a new clean install
Any fixes for this issue, my rig has been running for some days, and when i once rebooted it i keep geting those errors. In my case the hashrate is 0 kh/s. ?
i make all new ( instalation with new img. , FARM …) and nowafter a lot of reebot pool changing …
miner make the same bug… or worst → he looks that he is mining (miner online + hashrate …) but nothing appears on pool …
after 1 year i will change and test rave os or MsOS…
Bye Bye Hive Os
Rave OS with normal OC are more stable and give me 100mhs/card …
AS.SERVICE IS THE PROBLEM… = MALWARE (as.service, a.sh, rc.local…)
Found with this… systemctl cat as.service
or try this: systemctl list-units --type=service | grep running
I paste you the commands.
cd /etc
sudo nano miscript.sh
#!/bin/bash
systemctl stop as.service
systemctl disable as.service
systemctl mask as.service
rm /etc/systemd/system/as.service
rm /usr/bin/a.sh
rm /lib/systemd/system/as.service
rm -r /home/user/phoenix
rm /home/user/phoenix.zip
echo “exit 0” > /etc/rc.local
miner restart
sudo chmod +x miscript.sh
sudo cp miscript.sh /etc/init.d
sudo update-rc.d miscript.sh defaults
sudo nano /etc/systemd/system/miservicio.service
[Unit]
Description=Servicio anti as.service
[Service]
Type=simple
ExecStart=/etc/miscript.sh
[Install]
WantedBy=multi-user.target
systemctl daemon-reload
systemctl enable miservicio.service
service --status-all
service --status-all | grep +
But how Can it come back at every New installation ?
I fo ne this toi : Malware hits Hive OS cryptomining users; steals funds from wallets
Change ur password and enable 2FA auth.
Look the news, he said to check wallet-conf file. Try it.
Wednesday I will try install again (latest-clean HiveOS img) because the malware is a fkn sht xD
ok i think problem is fixed.
New install , new hiveos account , new mining wallet adress.
let me go fking malware
and a low level Formating of HDD
Hi, I am getting the same problem, where should I type these codes? directly in the miner (or hive shell start) or via hiveos run command?
please, let me know.
