I have 2 rigs and 3 rx570 4gb gpus.
Motherboards are Msi b450 gaming +(this is my main pc, that’s why), and asus prime h270. So, due to specs, h270 has 20 pci channels, and B450 16? or 8 +8(i haven’t found any chipset specs,but due to bios setups only 16).
The problem is that hashrate is too low. It should be 20-30 but i have less than 18 from each gpu. In asus board only 1 slot used, in msi both.
I’ve tried different configs, bios settings, vbioses, miner settings but the summary result was about 35mhs(11,16 on b450, 16-17 on h270). Theoretically I should have 20-30 mh/s from each gpu, but no… I understand why i can’t have so much performance on x8 ports(btw 11.9 and 15.64 mhs) but what’s the problem in the first case?
I think gpus are ok, as bought it from different people(there is only problem with 1 of it, some bad shares, and i think it might be a board problem).
So… I need advices as I have no clue how to solve the problem. My friend has about 50 mhs from 2 gpus in similar config(same gpu model), I have only about 45 from 3 gpus.
On my opinion the problem is in boards, but which one should I choose than?
P.S. Sry for my english.
