Hi , I’m new.
I’m using the config you can see below :
As you can see , same cards have higher values in hs to others, not for less , take a look at GPU 0 5 and 7
Those 3 are always “a step below” in hs terms.
The motherboard is a biostar TZ590 Duo + Celeron + 8 GB Kington DDR4 + Sandisk USB 3.0 SSD
2 x 850W Gygabyte + 2 x 1000W Gigabyte
The raisers are the same on each card , same cable run, similar temperatures.
This motherboard have 9 PCI ports out of the box.
The motherboard was configured with “GEN 1” PCIE
I’ve tried all types of overclocks + change PCI ports, raisers, processor , memory and motherboard.
Hash rate wont go up from there, kinda sad …
In the other hand I cant get all cards works in “close hash rate values” all together.
Any guidance or help ?
Thanks in advance.
